by m1dadio Mon Jun 14, 2010 5:13 pm
The 6 cylinder rad wont cut it, especialy a TPI V8 and it dosn't fit the V8 dog house anyway.
The V8 came with two styles of rads that I know of. An up and down flow and a cross flow. Some people will go for an aftermarket alluminum rad. I went for the 4 core v8 cross flow It just keeps the TPI engines cool enough. The TPI engine runs hotter then others and if the cylinders ares board oversize, expect the cooling to be a sensative issue.
You should expect to spend close to a grand on the cooling system, close to a grand on the exhaust system, close to a grand on gear shifter and accelerator systems combined. The list will go on, I've been there bud. 2K labour will get it partly installed. Has your mechanic ever installed a V8 into a first gen van? Will your new engine come with the wire harness, sensors and computer? The TPI harness from Painfull is about $400 alone isn't it?
Customising these vans takes research, homegrown engineering and trial and error, not to mention money. I havn't put 1000 miles on my power plant and allready I have spent more the 2Gs re-doing the TPI induction system to better suit the dog house and engine requirments. That also included re doing my rad cooling fan and wiring +relay requiements for the new fan because my first design was not addaquit for cooling the TPI. The most powerfull cooling fan you can get is the two speed Lincon Mark VIII 18" fan with shroud. You can find more info on that in the "how its done section".
Take a look at the picture link I sent you earlier. There is alot of modifications to be done and almost no afternarket stuff availible for these vans.
I hold alot of respect for the guys with these vans because not just anybody can own one. You have to be willing to do what it takes and persevere, and manage the projects carefully or it will test your phycological limits to places you havn't been before. I think others here can attest to that!
M1D
