am considering putting crate 350/330 w th350 in,any input would be helpful
crate 350 eng
Space Truckin- Number of posts : 1279
crate 350 eng
Re: crate 350 eng
Great combo cost effective,and would perform great without alot of expensive modifications. Bill
Re: crate 350 eng
Your van was made to take a 283 or 307 V8, a 350 should drop in there like butter
350 th350
what u have to look for before making a drive shaft is the bell housing is biger and longer it will hit where the doghouse meets the floor so engine cross member may have to be spaced lower the engine crossmember will go in backwards but it will hit the steering link then the van hits a bump so put engine and trans up in before making trans mount or driveshaft i have b&m cable shifter to th350 ed
Re: crate 350 eng
thanx ed , am trying to stay with stock linkage and column
Scott- Number of posts : 1651
Re: crate 350 eng
Is there an update on this?
I'm guessing you are pulling a Powerglide for the th350..
Just wondering how the stock linkage is working out?
Re: crate 350 eng
no scott , no update yet am still looking for stock column and shift linkage,no the shorty came w a 4 on the tree, i want the th350.found a deal in oregon on 2 donors but shipping was going to kill me . received neutral switches from you and again thanx .as soon as i find the right donor will post ,as you know it will be a long and winding road especially since i am trying to do 2 at a time
Re: crate 350 eng
Space Truckin, Is that the no door that was for sale in wash? Bill
Re: crate 350 eng
no , it was 2 window vans
m1dadio- Chevy Guru
- Number of posts : 1778
Re: crate 350 eng
Ok so Van Ed brings up something I have not heard of but is worthy of discusion.
"bell housing is biger and longer it will hit where the doghouse meets the floor so engine cross member may have to be spaced lower the engine crossmember will go in backwards but it will hit the steering link then the van hits a bump so put engine and trans up in before making trans mount or driveshaft "
Reversing the engine mount cross member?
After reading that I had a look at mine. According to what he is saying my engine mount has alwasy been in backwards. If my suspension plunges hard enought to squash the bottom out bumpers on the springs then yes it will hit the steering tie rod. But my 700R4 is sitting in my van just the same way I have seen in pictures of everybody elses. Aslo If I were to reverse my engine mount, that would put my engine about 8" further back. And ya, I would have to move the dog house back which would put the rad almost at the rear of the front seats. My engine cross member also has a drain hole right at the lowest point, If the mount were reversed that hole would not be at the lowest point anymore.
I had heard that the 64 with a 4 cylinder engine had the mount in the other way around.
So whats the gige! is mine backwards or is van Ed's backwards?
M1D
M1D
Re: crate 350 eng
M1, the 1st Gen vans came with the front crossmember slanted towards the radiator,,,,,,,,,
DanTheVanMan- Commissioner
- Number of posts : 7900
Re: crate 350 eng
Guessing when I get around to dropping in my 327 I will have these same issues....
m1dadio- Chevy Guru
Re: crate 350 eng
Thanks Don: that means mine is corect, I sort of figured it had to be or the engine would be way back. It is an interesting idea if you want a real mid engine van.
How are the 2nd gen vans? Do they slant? can they be reversed?
M1D
M1D
