Hello,. Any one out there got an A - van with bendix power steering ? The type that bolts to the drag link at one end and the pitman arm at the other. I need a new ball joint thats at the front of the unit and a repair kit for the rest. I think my control valve may be a bendix # 126342. I'd be glad if anyone could shed light on what other vehicles used the same part. Cheers. Simon.
A100 power steering problem
Re: A100 power steering problem
thats a rare opinion, hopefully someone here can help. The "A" guys check in if the post drops just bump it up so someone that can help sees it
jkr- Number of posts : 1148
all i can add is the system is quite simmilar to ford "mustang and other model" cars from the 60's and 70's so try to expand your search to them for parts. good luck
Ford used the power assist (different than a power box) and the earlier vettes and other chevys did too. A search using the name and number came up with this
http://www.straightlinesteering.com/Control%20Valves,%20Cylinder%20and%20Steering%20Cylinders.htm
I'm sure there will be others, contact them and see what will get you back on the road!
I've got a complete set from a '69 a108, but guessing from the cheers you aren't in the US?? Shoot me a PM if you're interested.
duane
duane
steering part
- Number of posts : 8729
THE A100 ANT THE VALIANT USED A
SORRY THE A100 AND THE PLYMOUTH VALIANT USED A FAIR AMOUNT OF THE SAME PARTS. I HAVE NO IDEA ON STEERING
BajaCharlie- Number of posts : 619
Registration date : 2010-01-07
well mine has a power ram connected to the tierod via clamps in the middle of it I went back to Mopar Flats and measured my old one.And picked up a Charger gas filler cap too.
