    A-100 doghouse seal?
    Number of posts : 3046
    A-100 doghouse seal? Empty A-100 doghouse seal?
    Post by RodStRace Sun Jan 31, 2010 9:57 am
    So I've found door seals, window track and whiskers, along with the windshield rubber.
    Vent window rubber is listed, any feedback on vendors would be appreciated. I'm going to use the 68 doors from the parts vehicle, not the 66 doors.
    Door lock seals and door handle gaskets seem to be available too. I've also seen front lense seals. Nothing yet on tail light seals, but they appear to be a common size.
    It appears that the floor plates and the 2 triangles behind the seats used seam putty.
    So aside from a couple other seals/grommets (steering column, speedo cable, shifter cable) that may be a common size, it looks like just about everything can be found. So the question is about the doghouse.
    The sides and bottom should be easy with regular roll sealer, but what are you using for the lid?
    I'd like to get together a shopping list so that when it's painted reassembly won't be held up by soft parts.
    A-100 doghouse seal? Empty Re: A-100 doghouse seal?
    Post by G-Man Sun Jan 31, 2010 12:03 pm
    Not sure if they carry them, but check with Steel rubber & restoration Specialties
    Number of posts : 740
    Post by kiwimopar Sun Jan 31, 2010 1:59 pm
    Steele is a good place to start they have lots of A100 bits
    https://secure.steelerubber.com/
    Dog house seal could be made from any type of compression material - foam or rubber etc
    SnarkyPoet
    SnarkyPoet
    Number of posts : 174
    Registration date : 2009-12-22
    Post by SnarkyPoet Mon Feb 01, 2010 9:19 am
    Mine is original, here's a link to a pic:
    http://vintage-vans.smugmug.com/Vans/Velma-Skooby/10727541_xmjnR#778531778_d2Wdy
    It's sort of a wedge shape, and it's attached to the lid, not to the doghouse itself.
    Post by donivan65 Mon Feb 01, 2010 10:03 am
    My 1st Gen Chevy came with a 5/16" square piece of rubber glued to the cover,,,,,but it did not seal very good. So I got the door weatherstrip off a Chevy S-10 and it fits perfectly,,,,,only thing it is clipped over the lip of the doghouse bottom. So maybe you might try something like that.......
    A-100 doghouse seal? Wstrip13
    oo3
    Number of posts : 290
    Post by oo3 Mon Feb 01, 2010 11:21 am
      Current date/time is Wed May 01, 2024 10:21 pm
