+8
neondv8
mo_1040
12 posters
    Hot Radiator Cap
    Hot Radiator Cap Empty Hot Radiator Cap
    Post by donivan65 Sun Jan 10, 2010 8:29 pm
    Now this has potential,,,,,a thermometer built into a radiator cap,,,,,even if you only use it as a piece of test equipment,,,,,,I am going to get me a couple,,,,,,,
    Hot Radiator Cap Therm_10
    Hot Radiator Cap Empty Re: Hot Radiator Cap
    Post by Vanish Sun Jan 10, 2010 8:34 pm
    Don is that Cap for Coolant recovery ???? or dose it Just spit it on the Ground ?????? what pound cap is it ???
    Number of posts : 7900
    Post by DanTheVanMan Sun Jan 10, 2010 8:39 pm
    That pretty cool! cyclops
    Hot Radiator Cap Qr_cod10
    Post by donivan65 Sun Jan 10, 2010 9:29 pm
    13 lb cap,,,,,,,It does work on coolant recovery systems, or it will spit it on the ground if thats where you got the overflow hose running to, it does not have the release lever,,,reads from 30 to 270 degrees
    Number of posts : 1383
    Post by chester42 Wed Jan 13, 2010 6:17 pm
    JEGS has these for $24.95. Also are presures from7 to 20 lbs.
    Post by donivan65 Sat Jan 16, 2010 9:39 pm
    And here they is,,,,,,,,
    Hot Radiator Cap Rad_te10
    Post by Guest Sun Jan 17, 2010 8:13 am
    Kragan carries them.
    mo_1040
    mo_1040
    Number of posts : 645
    Post by mo_1040 Sun Jan 17, 2010 10:56 am
    They have them at O'reilys also but alot more expensive if I remember right.
    Post by G-Man Sun Jan 17, 2010 2:32 pm
    Most Speed shops carry these or can get them in a day or two. Its a great idea even if its great once. Hot radiators don't get enough respect
    Number of posts : 383
    Post by bugeye bob Tue Jan 19, 2010 8:51 pm
    they have them at advance auto for $25. think i'm going to get the three gauge setup volts,oil press and water temp, about same price.
    neondv8
    neondv8
    Number of posts : 278
    Post by neondv8 Sun May 05, 2013 4:32 pm
    So I just picked on up. But it's mr.g part #2471s(16 psi)
    Will this work on a stock rad all so?
    Post by Twinpilot001 Sun May 05, 2013 4:37 pm
    seems in my memory - someone on the group had one on his vans radiator?? it gave only problems & leaked i do believe. affraid
    neondv8
    neondv8
    Post by neondv8 Sun May 05, 2013 4:45 pm
    Twinpilot001 wrote:seems in my memory - someone on the group had one on his vans radiator?? it gave only problems & leaked i do believe. affraid
    Yah....it doesn't feel like its going on as tight as it should. Or maybe it just me.
    NipRing
    NipRing
    Number of posts : 336
    Registration date : 2011-08-14
    Post by NipRing Sun May 05, 2013 6:18 pm
    I have one on mine and it works perfectly. Hasnt leaked yet. Had it about a year so far.
    Number of posts : 322
    Post by Wheelie Mon May 06, 2013 6:44 am
    I bet they are close enough to get the jist but I always trust the IR gun over any resistor based gauge from my experience and wide ranges I have seen right out of the box. You can pick up an IR gun for around the same cost as one of those caps and you can use it to check temp of pretty must anything you shoot the laser at. I like it because I can check t-stat housing, water pump outlet temps, and I check the radiator inlet and outlet and compare to test radiator efficiency. It allows you to narrow issues down quick. I have diagnosed stuck t-stats, clogged radiators etc. with my IR gun.
    Number of posts : 1778
    Post by m1dadio Mon May 06, 2013 5:28 pm
    Ya I thought they were cool too until I tried one. The first time it was used it died and the thermometer always reads overheat even on a cold engine. I have a buddy at Lordco and Napa and they both say they don't carry them anymore because most get returned do to leaking, wrong reading or they don't do the pressure they are supposed to hold.
    Most people I talk to say they are made in China junk and I am afraid I have to say I now share that opinion.
    Here is mine on a cold engine.
    Hot Radiator Cap Dscn0312
    M1D
      Current date/time is Sun Apr 28, 2024 12:53 am
