Both my brake lights and reverse lights do not work. Rear lights do work when turned on.
I need to know where the brake light switch is, I assume it is on frame? cannot see it with the belly pan on.
The reverse lights, should they be connected to the trans or trans linkage / switch somewhere?
Could really use a complete wiring diagram for the entire truck as it was butchered by someone along the way.
Any ideas?
Thanks
Any ideas?
Thanks
