I just replaced my carb to a carter yf i need a solid distributor to conectto it . Or if there is a way to make it work with the 66 original on the 240. any thoughts.
carb and distributor combo's
Re: carb and distributor combo's
Mallory - Unilite Electronic Ignition Distributor Series 45
like this
or does it matter? I have only changed to this carb cause i used it on my last 240 never a distributor though.
like this
that's the one. I have never had a problem with them
Is it plug and play whats the in and out on that ? Should i find a pro?
I;ve changed a distributor for the same but not a better or upgraded!
it is plug and play. I had mine installed by the guy that built my motor for me. You will experience better mileage and performance. It is a great distributor. I like it better than Pertronix.
