Now that the van is home, there's a million things to do. First we replaced the motor, read about that here -> https://vintage-vans.forumotion.com/between-the-seats-a-f16/replacing-the-6-in-the-mystery-machine-t589.htm
I call it the Mystery Machine because someone had previously painted it up like that, and I hope to do the same one day.
I started removing the wood floor someone had glued in...what a pain! I wish I could have a word with the guy that did it.....
The last little bit behind the doghouse must be melted in there from heat or something, I can't get it out. I think I'll have to use a hammer and chisel.
The good thing is, there's very little rust under the wood. More than I had hoped for, but very little. The worse rust is on the roof in the back corner, I'll deal with that later.
