hey gang, is the manual steering box the same for the 108 as for the a100. is the an aftermarket one? will one from a dodge pickup work? thanks.
steering front
wylee- Number of posts : 920
steering front
kiwimopar- Number of posts : 749
Re: steering front
Not sure, and No.
Pickup steering box will not work....without serious modification. The A108 might be the same, but I cannot be 100% certain.
I do however know that the only steering box that fits our vehicles without any trouble is the OE model.
Orientation of the input shaft, output shaft and physical mounting is all a big can of worms.
I tried to get a Vega box to fit - and that to me is the closest - but still requires a ton of work to make it fit. Also I had to special order the Vega box with reverse action to make it do everything it should. By the time I had it landed here and all the money spent, I had been convinced to forget about that - all the extra hoses and pump required....takes up too much real estate under the hood (engine cover) and electric is the way I am heading now.
Still not got the electric sorted, but at least I have the parts to convert now. That in itself took a ton of research and scouring parts yards.
wylee likes this post
69- Number of posts : 444
Re: steering front
At least the parts book doesn't show any difference between A100 and A108 (including the A100 Pickup). Makes sense to me, as the fronend is exactly the same...
I think, Kiwi meant the D pickups when he referenced "pickup doesn't fit".
dix, wylee and gary h like this post
Re: steering front
69 wrote:At least the parts book doesn't show any difference between A100 and A108 (including the A100 Pickup). Makes sense to me, as the fronend is exactly the same...
Yes....D series pickups is what I meant - thanks @69
Totally different shape of steering gearbox.
dix likes this post
