What does everyone use to replace the white fiber board headliner in their van? mine is damaged and stained. Where do you get that material?
lboast- Number of posts : 112
Registration date : 2020-11-01
69- Number of posts : 403
Re: fiber board headliner
Nothing. Keep the sheet metal visible
(sorry, couldn't resist)
still trying to figure out what the white board is, that goes in the overhead. does anyone have a name of what it is called?lboast wrote:What does everyone use to replace the white fiber board headliner in their van? mine is damaged and stained. Where do you get that material?
- Number of posts : 14737
If you use the Search tab at the top of the page and type in headliner, there are some threads about them...this one for example that uses Luan...
https://vintage-vans.forumotion.com/t2768-easy-up-headliner?highlight=headliner
gmytych and lboast like this post
Keith D- Number of posts : 381
I'm not sure that you will be able to find the correct factory installed fiberboard like material.
My suggestion would be to go to some automotive upholstery shops and see if they can get anything like it. They would probably have the best resources to get that kind of material.
gmytych, vanny and lboast like this post
Dan Scully- Number of posts : 237
If it is this style , it was used in cars , wagons etc. . Rem makes a lot of this style headliner material . My 64 880 wagon uses this type 6 diffrettnt panels held in by a snap in strip. Might connect them . https://www.remautoinc.com/
Last edited by Dan Scully on Tue Oct 19, 2021 10:47 pm; edited 1 time in total (Reason for editing : txt)
vanny likes this post
Dan Scully wrote:If it is this style , it was used in cars , wagons etc. . Rem makes a lot of this style headliner material . My 64 880 wagon uses this type 6 diffrettnt panels held in by a snap in strip. Might connect them . https://www.remautoinc.com/
the one section that is stained in my van does not have the holes in it. it is a solid material.
does anyone else attempt to stay with the original looking material? Im just looking for a name to call it so i can research it. So far all I have found is car style material for headliner, not the solid board.
gmytych likes this post
