I have acquired a sway bar to put on my 67. It came with the sway bar and the end link brackets. It did not come with the bushing mount brackets. I can see online where the endlinks and bushings are readily available. I need one that comes with the brackets for the frame mounted bushings or a source for the brackets. Anyone know of a source for polyurethane endlinks and bushings?
2nd Gen G10 Sway Bar bushings and brackets
mecnicman- Number of posts : 2
Registration date : 2021-02-28
gfleduc- Number of posts : 367
For the shaft to the frame; reading a parts book:
Front bracket GM P/N 383493 (Summit racing & others have them).
Bushing GM 3903083 | Moog P/N K5227 crosses over - with Ø.77" ID - what diameter is the shaft?
For the link and bushings: '67 only is 2nd gen unique that is uses the same 10" link bolt as 1st gen.
NAPA 265-1318 (Don't know bolt diameter - original GM was 5/16")
Moog K7275 has Ø 7/16" bolt
deepgrey- Number of posts : 1
Registration date : 2021-08-22
For future reference, the sway bar on my '67 is a 15/16" diameter, and I measured the end link bolts as 9 3/8" long from the end to under the bolt head.
