    Engine Block ID help
    wacko
    wacko
    Number of posts : 423
    Engine Block ID help Empty Engine Block ID help
    Post by wacko Mon Jun 29, 2009 4:05 pm
    Here is the number off of my engine : 3877178C
    Can someone tell me what size it is or provide me with a link to look it up. Thanks
    If this isn't the right number let me know where abouts i should be looking
    wacko
    wacko
    Engine Block ID help Empty Re: Engine Block ID help
    Post by wacko Mon Jun 29, 2009 4:11 pm
    Ok, so i did a google search myself (I know, I should have done that first) and found this page http://www.inliners.org/casting/numbers.html which says it is a Buick/Olds/Chev/Pont/GMC 62-78 230-250. How would I know if it is a 230 or 250 or did chevy only make one or the other?
    Post by Digz Mon Jun 29, 2009 4:23 pm
    From what I could get off this list ,it should be a 230 cid. Just took another look I see what you mean, it is a little generic on the ID
    http://home.znet.com/c1937/Cast.htm
    64chevy
    64chevy
    Number of posts : 364
    Post by 64chevy Mon Jun 29, 2009 4:27 pm
    If it's a 230/250 block the only sure way is to check the stroke since the bore is the same. As I remember a 230 stroke is 3.25 inches and a 250 is 3.50 inches.
    wacko
    wacko
    Post by wacko Mon Jun 29, 2009 6:28 pm
    i did some checking in some reference materials I have and it seems the 1966 was only available in a 190 and a 230. So i guess it is a 230.
      Current date/time is Mon Nov 25, 2024 2:30 am
