    Vent window positions
    Otto
    Otto
    Number of posts : 112
    Registration date : 2020-09-02
    Vent window positions Empty Vent window positions
    Post by Otto Sat Sep 26, 2020 8:03 pm
    Question for those of you that own window vans; I am assembling my camper and it only has two of the tip-out windows. Where is the better spot for these windows- the side or the rear doors? More importantly why?
    Thanks
    1940willys
    1940willys
    Number of posts : 4
    Registration date : 2018-02-20
    Vent window positions Empty Re: Vent window positions
    Post by 1940willys Fri Oct 09, 2020 4:31 pm
    I have opening rear windows in a 3rd Generation Econoline. when you have them open when driving they suck in Exhaust Fumes! Bad News!
    Otto
    Otto
    Post by Otto Sat Oct 10, 2020 9:43 am
    I have a modern E-250 with tip-out windows in the rear doors and love them; they do a good job of venting out dog smell, gasoline odors, farts, etc. I only get a hint of exhaust when the engine is cold and pulling out onto the road initially; after that nothing.
    I'm curious how the tip-out windows work on the side of the van. It appears that each window is positioned differently- one as a "scoop" and the other as a traditional vent. The scoop orientation seems a bit extreme in how much air it could direct into the van. It looks like that window would create a tornado inside. What happens when both windows are open? Does air simply short circuit and just go in and then out the other window? I have never driven one of these vans so that's why I'm asking.
    Number of posts : 2011
    Post by Barnabas Mon Oct 12, 2020 3:31 pm
    Ford put the "movable glass" window on the side doors and the left side wall. They never put them on the rear doors, though they do fit.
    If you drive with them open on the back doors, make sure you have open vents/Windows at front of van to force air out the rear door Windows.
      Current date/time is Mon Oct 02, 2023 7:16 am
