    Dual master cylinder swap
    docmcg
    docmcg
    Number of posts : 206
    Registration date : 2014-09-08
    Dual master cylinder swap Empty Dual master cylinder swap
    Post by docmcg Fri Jul 12, 2019 8:45 pm
    Has anyone ever done a master cylinder swap and installed a dual master cylinder? What MC did you use? I’ve put independent suspension up front and parallel four link in the back and am considering four wheel disc brakes but will for sure do a disc/drum setup.
    Number of posts : 8769
    Dual master cylinder swap Empty Re: Dual master cylinder swap
    Post by dix Sat Jul 13, 2019 4:19 am
    1973 dodge B-200 van mc,had disc in the front drums in the back the disc were not power brakes , meaning it did not have a booster . this is what i run with very good results with some minor cutting to fit.
    pdubu likes this post
    CJ66
    CJ66
    Number of posts : 24
    Registration date : 2017-01-05
    Post by CJ66 Thu Nov 28, 2019 9:15 pm
    If you are still interested in the dual master cylinder swap. I installed a corvette unit.
    69
    69
    Number of posts : 447
    Post by 69 Mon Dec 02, 2019 1:31 pm
    Why not take the dual master setup off the '69 setup for example? All parts available at rockauto, I'd say.
    69
    69
    Post by 69 Mon Dec 02, 2019 1:34 pm
    Oh, sorry, for a disc/drum setup, you'd need a different master cylinder. Need to check with a friend here in Germany, he just installed discs upfront.
      Current date/time is Fri Nov 22, 2024 1:15 pm
