Could y'all be so kind as to send a picture of your starter solenoids so I can ensure Ive got my wires placed correctly. Just about ready to fire this girl off
Starter solenoid
2frogstowing- Number of posts : 16
Registration date : 2019-04-02
Starter solenoid
69- Number of posts : 446
Re: Starter solenoid
The big stud of the starter is connected to the big stud on the starter relay, which is connected to battery +, very heavy wires (4 AWG?).
The small stud of the starter is connected to the starter relay. Do you have a wiring schematic? That helps in understanding to connect the starter relay correctly.
Maybe someone else can chime in with some pics.
- Number of posts : 2086
Remote starter relays have 2 large lugs for battery and starter, non directional, and 2 small studs. 1 small stud is labeled S for start and the other is labeled I for intermittent. The 'S' goes to the key switch start terminal and the 'I' goes to the coil positive to bypass the ballast resistor(which is wired to the run terminal on the key switch) when you are cranking the motor. Giving more juice to the coil to fire. S makes the switch and I will throw 12v from the battery as long as the key is turned to start. The relay is grounded through it's housing so it needs to be bolted to ground. Iow, there is no ground wire to any terminal. They make relays that look nearly the same that have a coil + and - instead of S and I but they should be labeled as such. Those relays lack the I. I assume Mopar used the Ford style. Otherwise it's just like any switch with a coil. Think of the I terminal as the normally open terminal, there is no normally closed terminal on a starter relay, except the lug you hook the battery to. And that's more like never open, unless the battery is dead
You're key switch "run" should go to the coil positive. The I terminal on the relay should go to coil positive or nowhere, it's optional. The coil ground should go to the distributor. The thickness of a matchbook cover should set the point gap well enough to run if there's nothing else awry.
