I am having a charging problem.. the guy i got it from said it was not charging..
it has a new alternator and a new voltage regulator..
the one down side of getting a old van.. someone always messes up the wiring..
i don't have a shop manual yet.. found some wiring diagrams on-line but not much help..
i have of course the main hot wire to the alt.. then there are 2 wires with the flat connectors for pos and neg feild.. not sure witch one goes where ..then there is a 4th wire thats just sitting there with no end...
dont know if it even goes to the alt..
if someone has a pic. or could take a pic of there alt wiring that would be great..
but has to be new style they used in 70 with the triangle shaped plug on the voltage regulator..
or i could just put a GM alt on it and be done with it..
