Recently purchased a 65 G10. After a few hundred miles the shift lever started acting funny. When i'm in first gear the column shifter drops down towards the floor. I have to lift it up towards the steering wheel before I can shift out of first. This has also made it difficult to find neutral from all of the gears. Do I just need to adjust the linkage or is this a bigger issue?
column shifter dropping in first gear
bhwalker0925- Number of posts : 5
Registration date : 2019-02-15
gfleduc- Number of posts : 367
I would start with checking the bushings at the steering column base.
http://www.vcvc.org/album.php?albumid=136&attachmentid=30725
Just for reference the linkage assy at the bottom of the shifter column is called "Transmission Control Assy"
The '65 I had in the '70's (shown in my profile) had the same characteristics - Being a young guy - I did not investigate /repair... I had learned to wiggle, pause, lift & shift - Drove it for years like that.
Buddyr- Number of posts : 48
Registration date : 2015-10-08
Awesome. Ill pull it apart this weekend and check the bushing. Thanks guys!
I see you are in San Diego, I live in Chula Vista. are you going to the Big 3 auto swap tomorrow or Sat.?
Stuck at my desk all day tomorrow. Ill be out there Saturday morning.
