    My brakes could use a little improvement.
    Skulptorchaz
    Skulptorchaz
    Number of posts : 326
    My brakes could use a little improvement. Empty My brakes could use a little improvement.
    Post by Skulptorchaz Sun Oct 28, 2018 12:41 pm
    Hey Guys,
    I just realized my brakes are not as "good" as I thought.- I use that term loosely. They were never great.
    Since I changed trany's from the 3 on the tree to a 700R, I don't have the engine helping me whoa this beast down. I'm not even sure they would lock up.
    Any suggestions???
    Thanks,
    Chaz
    Number of posts : 890
    My brakes could use a little improvement. Empty Re: My brakes could use a little improvement.
    Post by jrinaman Mon Oct 29, 2018 2:15 pm
    FRONT DISC BRAKES! one of the first things I did to mine. huge improvement.
    Skulptorchaz
    Skulptorchaz
    Post by Skulptorchaz Mon Oct 29, 2018 4:08 pm
    Sounds like the hot ticket!!! So what brakes do you use?? Where can I get them (cause I damn sure need'em! Smile Smile )
    Do you need a different master cylinder? Would a bigger better master cylinder work better with drum brakes??
    Post by jrinaman Mon Oct 29, 2018 6:44 pm
    contact m1dadio about the brackets, he is a member here and on vcvc. should be plenty on it if you do a search on either site. he has done all the research and design and that in itself exceeds the cost/value of the brackets. I used a corvette dual master and trans am calipers and rotors. all cheap from rock auto and should just replace your rear shoes, wheel cylinders and lines while your at it.
    Skulptorchaz
    Skulptorchaz
    Post by Skulptorchaz Tue Oct 30, 2018 6:11 am
    Awesome man, thanks!!!
    Number of posts : 1383
    Post by BILLS66 Fri Nov 02, 2018 3:30 pm
    Do the front disc/dual master conversion ! You won't regret it ! Bill
    Skulptorchaz
    Skulptorchaz
    Post by Skulptorchaz Wed Nov 07, 2018 11:41 am
    I contacted M1Dadio but no response. Could it be he does not do this anymore? Maybe he just hasn't checked in lately. (??)
    I would like to pursue this if you guys have any other suggestions.
    Thanks a bunch.
    Chaz
    Number of posts : 1651
    Post by Scott Wed Nov 07, 2018 11:49 am
    He still does it, his improved design was available last year. I installed the first design on mine.
    Skulptorchaz
    Skulptorchaz
    Post by Skulptorchaz Wed Nov 07, 2018 6:21 pm
    Well, I'm in for a set. Hopefully he will let us know if/when he will do some more. I keep hearing good things.
    Thanks!!
      Current date/time is Mon Nov 25, 2024 5:20 pm
