Since all I can do currently is dream about my future a108 I have spent a lot of time researching and planning. Please excuse any naivety and feel free to share your experiences. I have a few other theories coming.
So obviously people have been running these vans stock just fine for decades so if in good order there is likely no need to mod but....inherently the doghouse is not a great design to flow hot air out to drop temps and provide cool air for the intake.
My theory part 1
If you expanded the DH towards the back it would give more space for air to escape out the back after the fan has blown hot rad air back at the engine. My guess is you could start half way down the back of the DH for ease and lack of curve and just slant out a few inches creating a much bigger area for air to escape. I am guessing header wraps would also help a ton as heat from the headers rises.
Cold air intake
I found this pic which uses an insulated tube which looks pretty sweet. Obviously this means you are using an electric fan. The other possible option would be to port the driver side of the DH and run a tube out the side and use a tube to go down through the floor behind the driver seat.
Now many wont want to go this route since you are cutting the floor and the DH even though you could easily make port covers but the one advantage could be that if you had a situation where the inside of the cabin was cool (maybe with ac) and the outside was hot (traffic in the Lincoln tunnel choked my Mustang) you could have the cold air box pull cold air from the cabin temporarily without exposing the cabin to the DH temps. Also could work if you had to driver through water where you might be concern about pulling air from so low. Regardless....if you are going low one would likely want to shield from puddles.
Thoughts? Experiences?
My theory part 1
Cold air intake
