    Door hinge pin question
    Cdcracing
    Cdcracing
    Number of posts : 245
    Door hinge pin question  Empty Door hinge pin question
    Post by Cdcracing Fri Jun 08, 2018 9:00 pm
    What is the best way to remove the pins in the door hinge ? I’m pretty sure mine has been in there since 1961 . The guy that’s doing my van says that he can’t get them out . So I’m going to try . Any advice would be appreciated. Also is there any aftermarket hinges for it ?
    E
    jdlaugh
    jdlaugh
    Number of posts : 298
    Door hinge pin question  Empty Re: Door hinge pin question
    Post by jdlaugh Sat Jun 09, 2018 7:24 am
    I used a big hammer and a punch. However, there are tools available, like this one (which I haven't used personally) hinge pin tool
    Looks like the Eastwood tool and another from Bob Drake are both listed as out of stock.... Crying or Very sad
    Carl
    Number of posts : 143
    Post by Carl Sat Jun 09, 2018 8:23 pm
    I did grind mine down until the head was gone, then you can punch it out from the top
    Number of posts : 1466
    Post by uante Sun Jun 10, 2018 10:00 am
    One of my doors has a sloppy hinge and I looked into replacing it. As far as I found, there are no aftermarket hinges. But you can buy new pins. I bought a pair of standard size ones and a pair of oversized ones. My plan was to get mine out and assess the situation, whether to oversize or use original with a sleeve...never got around to doing it though because it's on the least used door, the back right door. Wink
      Current date/time is Fri Nov 22, 2024 5:09 pm
