I'm trying to get an accurate reading for my stock temperature gauge.
I replaced my mechanical regulator with an electronic regulator from RTE, and calibrated my temp gauge to 10, 23, 73 which is standard.
Digging around on the web and making some phone calls, the consensus seems to be that Mopar gauges should read 190 in the middle. However, my 69 A108 FSM shows a resistance wire going from the sender to the gauge, and I confirmed that mine reads 5.8 ohms, which is what jkr also reported here:
https://vintage-vans.forumotion.com/t32426-a100-temp-gauge-resistance-cable#222866
Now here's where it gets interesting. I bought a new sender from Napa (Echlin), and the spec sheet says 15-19 ohms at 220 degrees. So with the resistance wire on my van, I interpret this to mean the gauge should see 20.8-24.8 ohms at 220 degrees. If that's the case, how on earth could the temperature be 190 in the middle of the gauge (23 ohms)? If I removed the resistance wire, it sounds like it *would* be around 190 in the middle. I pulled my sender off the engine, and while still running through the resistance wire to the gauge, put it in a pot on a burner, and my temp gauge reads ~207 degrees.
Does everyone also think we should be at 190 in the middle to the gauge? Do all Mopars have this resistance wire, or could it be calibrated based on where the sender sits in the engine? 17 degrees is a hell of a ways off, which is why I'm concerned.
