    Blinker one side doesn't work and tag light?
    bluedaze
    bluedaze
    Number of posts : 1
    Registration date : 2018-05-08
    Blinker one side doesn't work and tag light? Empty Blinker one side doesn't work and tag light?
    Post by bluedaze Wed May 09, 2018 12:48 pm
    Anyone had a problem with this? I have a 1967 Chevy Van, all the other blinkers are working, seems like all the fuse are good, the bulbs are also good on the blinker and tag light but these are not working. Do these go together?
    The one side front blinker> tag light?
    Any ideas?
    Thank you
    Blue Daze
    Number of posts : 1651
    Blinker one side doesn't work and tag light? Empty Re: Blinker one side doesn't work and tag light?
    Post by Scott Wed May 09, 2018 1:41 pm
    The 67 didn't have a tag light, just a reflector.
    It wasn't until 69 that the tag lights lit.
    Number of posts : 12245
    Post by donivan65 Wed May 09, 2018 1:43 pm
    tag light connects to left rear tail light wiring inside van,,,,,and see if bulb is grounded,,,and which are we talking about front turn signal or rear,,,,,do the brake lights work,,,do the tail lights both work,,,,,make sure someone did not put a single filament bulb in turn signal or a double in the tag light,,,,and we are talking about license plate light not side markers, right?
    Post by Scott Wed May 09, 2018 1:59 pm
    I was thinking Side Markers when I said reflectors only..
    Post by donivan65 Wed May 09, 2018 4:39 pm
    ,,,,,,,that 67 sure is different than a 66 or a 68,,,,,,,leftover 1st Gen parts, not enough 2nd Gen parts,,,,
    sandyvan
    sandyvan
    Number of posts : 526
    Post by sandyvan Tue May 15, 2018 2:49 pm
    Scott wrote:I was thinking Side Markers when I said reflectors only..
    My 69 as I recall doesn't have any wiring to the side markers, I'll have to check again. All the lights that are there work though...
    kookykrispy
    kookykrispy
    Number of posts : 1533
    Post by kookykrispy Thu May 17, 2018 7:48 am
    One side turn signal not working would indicate a possible faulty turn signal switch. you can get a replacement at Orielly's
      Current date/time is Sun Nov 17, 2024 12:42 pm
