Hi Vanners,
Got the disc brake swap done a few weeks ago and have been driving it often. I installed all new wheel studs, hubcentric 1" spacers in rear and finally got all lugnuts and studs figured out. I ended up going extended since I had the room, but had to mill the ends down a bit so everything would tighten properly. I spent a lot of time tracking down correct studs, spacers and lug nuts!
I changed out the master cyl that I previously installed which was for drum/drum. The one I installed was quite a bit larger so took some additional mods to fit it, and new lines.
Everything is working OK but the pedal does travel farther then would like it to. I think I may need a residual valve for the rear.
It drives really nice with fresh king pins, shocks, bushings and lubed up/adjusted steering box.
The wheels fit nice and look great. Tires are 235 70 15 BFG's on 15x7 TT D's. The front inner wheel well required some minor trimming to fit, but they do not rub at all. Glad these all fit, even with these wheels clearance is still pretty close to caliper.
Also picked up a 273 so finally doing that v8 swap. It has 81K on it and supposedly ran well when removed. I saw the car it came from, a 68 Dart GT conv that is getting restored and big block/4spd installed (the guy also had a beautiful, concourse condition black 70 charger RT 440)
I got the bell housing in the mail yesterday, have pretty much everything I need except not sure on exhaust manifolds yet.
The plan is to go into the engine and see what is what. If it is in spec, pistons/cyls good, I will rebuild it stock. If I need pistons or bore it will be built to commando specs. Not looking for a real hot rod here, the stock 2bbl 180 HP 273 is still like 50 more HP then it has now. I really just want to get rid of that "mail truck" sound... I did a lot of research on hopping up the slant, but decided I need a v8 in my life again...
Taking it camping with the fam next week, will tow the little 66 Cox tent trailer behind it.
