+8
NipRing
12 posters
    Removable Chevy Doghouse
    Number of posts : 331
    Registration date : 2009-02-24
    Removable Chevy Doghouse Empty Removable Chevy Doghouse
    Post by crazee Fri May 29, 2009 9:32 am
    Anyone here convert their doghouse to be removable like a FORD has?
    Looks to be an easy mod.
    Any input on this idea?
    Thanks.
    Smile
    Removable Chevy Doghouse Empty Re: Removable Chevy Doghouse
    Post by Guest Fri May 29, 2009 10:26 am
    I drilled my spotwelds out over 20 years ago. It makes it so easy to remove the doghouse to pull the engine or even to clean and paint the engine and surrounding parts. I reattached it by using short sheetmetal screws.
    Number of posts : 1651
    Post by Scott Fri May 29, 2009 10:35 am
    Seems like an easy mod..
    What did you use to seal between the Doghouse and floor?
    Since the seats connect to the Doghouse you should secure it really well to the floor again. You may also have to move the wire harness if it still passes through the wall of the doghouse, and anything else connected to the doghouse wall.
    Post by G-Man Fri May 29, 2009 10:44 am
    I am working on that right now, only diffents is mine will bolt down. I also am interested in what type of gasket to use. Another thing to remember is if it removable you may need to move something that attach to the doghouse.
    Post by crazee Fri May 29, 2009 1:22 pm
    Why not just use clear silicon to seal doghouse? Heat proof, water proof and a snap to peel off and re-apply as needed.
    Also how about just adding connector plugs into any wiring ?.........that way just unplug and leave such things in place.
    Of course there is the issue of manual choke and E-brake.
    ALSO.........pics of this done or being done would sure be helpful to all.
    Number of posts : 7905
    Post by DanTheVanMan Fri May 29, 2009 6:41 pm
    Removable Chevy Doghouse Qr_cod10
    Post by G-Man Fri May 29, 2009 6:59 pm
    I really think some type of rubber gasket is the way to go. (for me anyway)The idea of cleaning off old silicone and reapplying everytime just would add time I don't have.
    Post by DanTheVanMan Fri May 29, 2009 7:26 pm
    Yeah, that would be better if you plan on removing it often. I just don't see me doing it other than for a powerplant remove or install. But man, it would really be nice for that!!
    Number of posts : 987
    Post by RipVanArkie Fri May 29, 2009 8:51 pm
    Am I the only one that pulls their engine out the bottom? So easy!
    Later,
    Rip
    Post by G-Man Fri May 29, 2009 9:03 pm
    For me it not so much for motor changing, it for doing service on mine without getting 3rd degree burns from headers
    Number of posts : 378
    Post by xjamesx Fri May 29, 2009 9:16 pm
    mine wasnt a complete removal/ bolt-in but here are a few pics that might help...
    http://vintagevans.forumup.jobs/viewtopic.php?t=8836&mforum=vintagevans
    the flange from the donor D/H was rusted (and i needed to shorten the height to match the original one) so i made a sheetmetal flange and drilled holes and bolted it in. i have some flat rubber to seal it but i wanted to paint it first , which i havent done yet, so point is, with no sealant and just bolted in, i dont notice any heat or odor slippin in.
    good luck,
    james
    NipRing
    NipRing
    Number of posts : 336
    Registration date : 2011-08-14
    Post by NipRing Tue Apr 10, 2012 11:23 am
    I'd like to see these pics but my login doesnt work on the old forum. Anyone help me out?
    Number of posts : 12248
    Post by donivan65 Tue Apr 10, 2012 12:17 pm
    Removable Chevy Doghouse Dogged10
    NipRing
    NipRing
    Post by NipRing Tue Apr 10, 2012 1:11 pm
    Yeah, thats kinda what i'm thinking. Weld some bolts all the way around from underneath and secure the doghouse down that way. For the best access. Rather than weld it down permanent like.
    Post by Big W Tue Apr 10, 2012 4:29 pm
    It has always been my understanding that silicon and mettle are a bad mix. A while back I had posted a response to silicone around a windshield...it had eaten almost the entire mettle lip that holds the gasket to the frame. Hit the brakes real hard one time and the windshield took off. Now I don't no about engine gasket silicone, if this is different stuff, but tub and tile is what my Dad always used and everything he had that on rusted out. Somebody set me straight on this or am I wrong on house hold silicone on vans and trucks scratch
    Post by Twinpilot001 Tue Apr 10, 2012 6:00 pm
    Dzus fasterners work very well
    Post by Digz Tue Apr 10, 2012 6:13 pm
    When your run of the mill silicone cures it releases an acetic acid (sp)? I have made the mistake in the past using it for sealing conduit on an enclosed electrical panel, it creates corrosion something fierce. If RTV is different Im not sure.
    Number of posts : 1868
    Post by HandiVanMan Tue Apr 10, 2012 8:14 pm
    Maybe You could take an old heavy duty 18 wheeler tire inner tube and cut a rubber gasket out of it??? Could glue it to the bottom of the floor.
    Post by donivan65 Wed Apr 11, 2012 12:20 pm
    Removable Chevy Doghouse Img_0310
    Removable Chevy Doghouse Img_0312
      Current date/time is Mon Nov 25, 2024 7:59 pm
