The van starts when the motor is cold no problem but after I've been driving a while and shut it off, it either barely or just plain won't turn over. I put shorty headers in and the one is real close to the starter so could heat be the problem? Still haven't got the belly pan or the burger fan in so maybe they will help.
Starting issue
samsvan- Number of posts : 672
Starting issue
Re: Starting issue
Thats a common problem,,,,,,juice has to go from the battery,,,,,,through a connector by the carb,,,,to the ignition switch,,,,,,back through the connector by the carb,,,,through a safety neutral switch if you have an auto trans, and finally to the starter solenoid for it to turn the starter on,,,,,,,,and when the engine is hot, it gets harder for it to turn,,,,,so you get that heat soak,,,,,,,we put a relay at the starter solenoid, so that the ignition switch turns it on and the relay just sends the juice from the positive cable post on the starter solenoid over 1 inch to the S terminal which turns the starter on,,,,,,,
Re: Starting issue
Re: Starting issue
,,,All Chevy engines suffer from the hot hard start problems,,,,,especially V8's,,,,,,,,to check if it is an electrical problem, use a jumper wire, starter button or screwdriver to jump from B to S on the starter when you run across a hard hot start problem,,,,,,,is the battery good?,,,,,,I have put a relay on every Chevy I own and well as everyones around me,,,,
Re: Starting issue
Re: Starting issue
Cool, I'll give it a shot. Thanks again.
Re: Starting issue
Got the solenoid in and took it for a test drive. Success!! Thanks Don.
