jeepsterhemi
lws67
    Removing Fuel Filler Neck
    lws67
    lws67
    Number of posts : 193
    Removing Fuel Filler Neck Empty Removing Fuel Filler Neck
    Post by lws67 Sun Nov 06, 2016 3:03 pm
    Can someone tell me how the filler neck comes out? Got the tank out, all hoses, 3 screws to mount filler neck to body side, the clamp and bolt for attaching the pipe to underside body panel, and the small plate and seal w/3 screws from underneath removed, but the pipe won't come out from below and not through the taillight opening.
    jeepsterhemi
    jeepsterhemi
    Number of posts : 79
    Registration date : 2012-02-20
    Removing Fuel Filler Neck Empty Re: Removing Fuel Filler Neck
    Post by jeepsterhemi Sun Nov 06, 2016 3:35 pm
    From A100 Compact Service Manual.......
    Removing Fuel Filler Neck Fuel_t10
    Number of posts : 14778
    Post by vanny Sun Nov 06, 2016 4:11 pm
    Sorry, it looked like it was getting cut off so I changed the pixel settings to 640 so you could see the entire page.
    lws67
    lws67
    Post by lws67 Sun Nov 06, 2016 4:51 pm
    Well damn, I'll have to try it again in the morning with more patience. Must be one sweet spot where it comes out that I haven't found. Thanks
    rustytoolss
    rustytoolss
    Number of posts : 624
    Post by rustytoolss Sun Nov 06, 2016 6:31 pm
    I've got a question, Can the small vent hose be replaced without dropping the tank ? I have not look at this yet. But have gasoline smell near back of my pickup. And there are no visible leaks.
    lws67
    lws67
    Post by lws67 Sun Nov 06, 2016 7:25 pm
    I replaced mine a while back without removing the tank, its a pretty tight squeeze (and filthy) to get the old ose off the barb, and the new on, it can be done. The fill hose on mine didn't leak, but it sure let off fumes. As I pulled it off the tank it tore very easily before I could fully get it off.
    Number of posts : 1564
    Post by OutofSight Sun Nov 06, 2016 8:01 pm
    I have only removed mine after removing the tank.
    68vanman
    68vanman
    Number of posts : 124
    Registration date : 2012-09-29
    Post by 68vanman Mon Jul 29, 2019 12:11 pm
    I tried removing mine the other day, and it's difficult. I may need to raise the back of the van a little higher because I still can't get it out.
    When I had removed the hose that connects the tube and tank, a bunch of rust fell out. Now I know that I need to clean out the inside and or replace it. Had I not done this, filling up with gas would have washed it all into my new tank.
    Removing Fuel Filler Neck Img_3514
    Removing Fuel Filler Neck Img_3515
    Removing Fuel Filler Neck Img_3513
    Post by vanny Mon Jul 29, 2019 7:00 pm
    Yuck! Good thing you caught it!
    68vanman
    68vanman
    Post by 68vanman Sun May 10, 2020 12:31 pm
    After a long hiatus, I got back to working on the van yesterday. I guess taking a break was a good thing because I figured out how to remove the fuel filler tube. So for those who need some pictures to explain, here you go. There is a bracket  that fits around the tube and is held into place with some small tabs. I tapped upward and it separated easily.
    Removing Fuel Filler Neck Fuel_f10
    Removing Fuel Filler Neck Fuel_f12
    Removing Fuel Filler Neck Fuel_f11
    Removing Fuel Filler Neck Fuel_f13
    Removing Fuel Filler Neck Fuel_f14
    Post by vanny Sun May 10, 2020 12:40 pm
    It's funny how that sometimes happens when you take a break and things just seem to work out when you come back to it...Thanks for posting pics and explanation, that may help someone else if they run into the same issue in the future. cheers
      Current date/time is Sun Nov 17, 2024 4:23 pm
