    1967 Dodge A108/A100 Load Adjusting Air Shocks???
    Vantera
    Vantera
    Number of posts : 7
    Registration date : 2016-08-19
    1967 Dodge A108/A100 Load Adjusting Air Shocks??? Empty 1967 Dodge A108/A100 Load Adjusting Air Shocks???
    Post by Vantera Mon Aug 22, 2016 1:24 am
    Hi guys,
    Can anyone recommend a good load adjusting air shock that will fit an a-108/a-100? Neither Monroe, Summit or Amazon show any that are compatible.
    Currently, I have gas shocks with an 11.875” Compressed Length, 6.375" Travel Length and 18.250” Extended Length. They were on the van when I bought it
    Also, I bought a Dorman 31001 Shock Mounting Kit/assembly for the bottom and it won't fit any of the Monroe shocks as the eyelets or Loop Bushing& Sleeve Mount rather are too small. Any suggestions? Should i push out the metal sleeve and rubber bushings out of the shock and then use the one's that come with the assembly? They don't have a metal sleeve, does this matter?
    Would be grateful for any advice. Thanks very much! pirat
    Brandon2
    Brandon2
    Number of posts : 54
    Registration date : 2016-01-18
    1967 Dodge A108/A100 Load Adjusting Air Shocks??? Empty Re: 1967 Dodge A108/A100 Load Adjusting Air Shocks???
    Post by Brandon2 Mon Aug 22, 2016 8:59 am
    I'm not a suspension guru, but I could not find any that fit off the shelf either.
    I had to have them made/crafted by a local suspension place, so it's at least possible to put something together if you know what you're doing.
    rustyspoke66
    rustyspoke66
    Number of posts : 180
    Post by rustyspoke66 Sun Aug 28, 2016 9:40 am
    I installed a set of Monroe MA-704 air shocks on my A-108.
    https://www.amazon.com/gp/product/B000C55T1I/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1
    I also installed Monroe 58484 load sensing shocks on the front.
    https://www.amazon.com/gp/product/B000CGEJJU/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1
    gmytych likes this post
      Current date/time is Mon Dec 02, 2024 8:07 am
