SO I had a bit of change of plan, actually it's a whole change of direction in an area that I didn't suspect I would be doing much work in. The Engine. I pulled it out before I painted the underside. I wasn't even going to pull it out but it just made the painting easier. So as long as I had it out I got a gasket set to open it up and reseal it. When I pulled the heads I saw that it had been recently rebuilt and bored .020. No ridge, everything looked good if not a bit gooky from sitting for so long.
One thing that caught my eye was the deck height seemed really low. Now the 318 is not known for lots of compression and this one fell right in line with that. I measured a few things and did a little math and came up with 7 to 1 compression,,, that can't be right so I measured everything again carefully and came up with,,,, wait for it,,,,, 6.98 to 1. Yuck, so a set of the KB raised compression height pistons will fix that, and the .325 lobe lift cam isn't going to do either so a cam, springs etc and that is alright.
The valve train looked a bit odd from the top, all the exhaust valves had a lot taller installed height so I popped one out. They were all recessed about .070. Sigh, so a set of heads right? Not worth putting seats in plain old 318 heads. SO I go to a pull a part in 95 degree weather and pull a set of magnum heads off a B van. Get them home, check them out and,,,, cracked...
At this point I am assuming the universe doesn't want an LA engine going back in the little A100. So more math and it works out that I would be just a few hundred dollars more to do this.
It's a 2013 5.7 Hemi from a truck with 38k miles. It's an ugly rascal but it should make plenty of power and the AC is going to be really easy. Also the drive belt is already largely sorted. I will probably go with the MegaSquirt plug and play with it just to save time and the complexity of modifying the stock harness. Surprisingly enough LKQ only cut two little spots on the harness so if I wanted to I could use this one with a stock controller and an HP tuners programmer. The only hold up with that would be being able to defeat the SKIM, security, in the stock computer. They are close to having that sorted so we will see how that goes. I'm hoping I am done before they are actually cause I want to be DONE!!!
But the exciting news for the day, Something went back on it instead of off!!! That's huge news indeed.
New spring bushings I made using UHMW and new sleeves, I like this material for bushings and it should stiffen things nicely.
