I was fooling around with the Northern Industrial 125amp flux core welder I got for Christmas from my kids. After watching hours of you tube videos I decided to give it a try. I know using gas gives the best results but its not an option on this one, so I am going to try and work with it for now.
The picture below is what I got as far as penetration. Does it look acceptable? With the wire speed set at 2 and the power set at 1 I got the best results. Any higher power or wire speed and it burns right through. It's my first time using it and I have more metal to practice on.
I saw on you tube this anti splatter spray stuff you spray on before you weld and then wipe away the slag, anyone try it?
Any input would be greatly appreciated.
Richie
Richie
