I need a radiator for my '63 E100 pickup. I thought the one in it was good, but after the radiator shop looked at, he said it needed replaced. I am putting in a '65 Falcon 200 motor. The thermostat housing is 1 1/4" outside diameter, and the water punp opening is 1 1/2" outside diameter. What are my radiator options? I saw two on e-bay, #30175960948 and #251814178812. The one looks like it will fit in the truck, but the openings are too big.They list the top opening at 1 1/2", and the bottom at 1 3/4". You guys that are running the 200's, did you have the same issue? Any and all help is appreciated.
John
John
