+4
Oldpro
8 posters
Carpet Job
Re: Carpet Job
that looks awesome! it'll be even nicer in the van! we're all waiting for new pictures!
wylee- Number of posts : 917
Re: Carpet Job
nice job,guy's
Re: Carpet Job
I like that idea, Oldpro! Nice job! I wonder if laying a couple removable carpet panels on the floor would be beneficial, rather than fixing it to the floor! I'm a few months away from that point, so you'll need to share some results later!
Re: Carpet Job
Looks Great!!!! Vanna better watch out looks like your after her job!!!LOL
xjamesx- Number of posts : 378
Re: Carpet Job
that looks great! lets see some "in the van" pics!
and keep up the good work...
james
james
Re: Carpet Job
Awesome. If I get to that point, I just hope I can remember to carpet the correct side of the plywood.
Vanish- Admin
- Number of posts : 5155
Re: Carpet Job
That Looks GREAT !!!!!!!!!!!!!!!!!!!!
,,,Vanish,,,
MCMLXV
Oldpro- Number of posts : 28
Registration date : 2009-03-16
Re: Carpet Job
sasktrini wrote: I wonder if laying a couple removable carpet panels on the floor would be beneficial, rather than fixing it to the floor!
Removable Panels Pros and Cons
Pros
-e-z removal
-e-zer to clean
-If the carpet is damaged, you only have to remove the one piece and replace less carpet (If both pieces are damage, then it’s just the same as doing the carpet in one piece, nothing lost, nothing gained)
Cons
-Seam in the floor
-more cutting to do
- you have to cut each piece just right, or in might fit weird.(Same thing for a whole piece)
- might move a little if not cut right
If you can think of any more, add to it.
Re: Carpet Job
I never thought of doing the way you have done it. I have to say I think the pro's out weight the con's in what you have done.
Here a few for the Pro's
Our vans are old and you just don't know if something may need repaired under that carpet. Being patching etc... And think if the wood was glued down or screw to the floor the work that would have to be done just to get at the problem. Plus screwing down the wood would just be inviding rust on the undercarriage.
Re: Carpet Job
looking good
