Nice van. Keep up the good work.
+8
jseiff
12 posters
The Dodge Lodge
sweetvan- Number of posts : 242
Registration date : 2013-12-16
- Post n°26
Re: The Dodge Lodge
Tice84- Number of posts : 124
Registration date : 2015-10-10
- Post n°27
Re: The Dodge Lodge
Looks great. Are you going to put a coat on the OSB or leave it as it is?
jseiff- Number of posts : 32
Registration date : 2015-09-11
- Post n°28
Re: The Dodge Lodge
I have left as-is for now but plan on putting a vinyl or laminate floor over the top.Tice84 wrote:Looks great. Are you going to put a coat on the OSB or leave it as it is?
- Post n°29
Re: The Dodge Lodge
I see the links are broken now for previous pics, and so I will re-upload the images here.
- Post n°30
Re: The Dodge Lodge
- Post n°31
Re: The Dodge Lodge
- Post n°32
Re: The Dodge Lodge
- Post n°33
Re: The Dodge Lodge
Just threw up a bunch of new pictures.
Other updates:
- replaced upper radiator hose and flushed system
- cleaned transmission pan; replaced filter, gasket, and fluid
- currently have rear differential partially dismantled to replace gasket and a couple other small things
Had too many leaks under this bad boy!
All the best,
Jordan
Other updates:
All the best,
Jordan
Big W- Number of posts : 3282
- Post n°34
Re: The Dodge Lodge
Looking real nice. Loving the wood grain.
- Post n°35
Re: The Dodge Lodge
Nice clean work and as BigW said, Love that wood grain! Should be a whole lot more quiet too!
- Post n°36
Re: The Dodge Lodge
Looks good, Jordan, I very much like the wood you used
- Post n°37
Re: The Dodge Lodge
Wow Jseiff, this is exactly the style of look I am also planning with my A 100. Much continued success and thanks for posting your project.
- Post n°38
Re: The Dodge Lodge
Coming along nicely, looks great.
- Post n°39
Re: The Dodge Lodge
How are you going to do the wheel well covers, also with wood?
- Post n°40
Re: The Dodge Lodge
I don't have a final plan for that yet. Probably not with the same wood, but I do wanna add some sort of insulation to match the relative value of the walls/ceiling. I'll be adding a bed/storage area over the top of the rear driver's wheel well soon.westcoastvanner wrote:How are you going to do the wheel well covers, also with wood?
- Post n°41
Re: The Dodge Lodge
Looking forward to see what you come up with, as I am nearing that phase myself.
