I have a 69 g10. Just got my tank and sending unit professionally refinished.Then ran all new hard line, new fuel pump, and new inline fuel filter before the carb(clear plastic inline one). And this is on a 250 inline 6 with a mechanical fuel pump.
Long story short I'm not getting fuel, you can see in the clear inline filter its not filling the lines. But the weird thing is its intermittent. Sometimes I walk outside, the fuel line is full, I fire it up and it runs fine. Then dies out once I drive faster than neighborhood speeds. Then other days I come out and the line is clear and no matter how much the motor cranks pumping that little mechanical pump I still get no fuel. The van will fire up and idle fine on fumes but you can't take it out for a drive.
Anyone have any ideas what might be going on? Soon I may just swap to an electric pump but I would like to run the mechanical if can.
Also on another note this is the 4th fuel pump I have tried. All with the same issue. All have been through Advance, part # 40446
Thanks for any info.
