First off I do not have a fuel leak of any type... But I do notice gas odor around the back of my pickup ( more so when full/ or warmer outside). I have the chrome OEM type Vented gas cap. Was it normal back in the day, for vented gas caps for gas vapor fumes, to be noticed from the cap ??? I would not think so! I just sprayed some PB Blaster into the vent spring of the cap to see if that helps.
Speaking of gas caps..Those of you that have replaced your OEM cap with the 68-70 Charger flip gas cap. Did you have to make any modifications ??
