    will a 300 from a 1979 4x4 truck with manual trany bolt up to my stock c4 trany?
    Number of posts : 134
    Registration date : 2011-02-26
    will a 300 from a 1979 4x4 truck with manual trany bolt up to my stock c4 trany? Empty will a 300 from a 1979 4x4 truck with manual trany bolt up to my stock c4 trany?
    Post by wildbillinva Sun May 24, 2015 2:59 am
    Question the title says it all. I have a chance to get this motor for $300.00 bucks. guy says I can hear it run. what do I need to look for as far as the trany bolt pattern. I have a 1966 falcon deluxe club wagon with a 240. how about oil pans? any help would be great.
    Number of posts : 864
    will a 300 from a 1979 4x4 truck with manual trany bolt up to my stock c4 trany? Empty Re: will a 300 from a 1979 4x4 truck with manual trany bolt up to my stock c4 trany?
    Post by Casimier Sun May 24, 2015 5:00 am
    I put a 300 in my truck from a 79 pickup.
    It bolted right up to my C4 automatic trans. Everything fit easily.
    Make sure you use your old oil pan and.
    Check the dip stick tube location on your new 300. Some go to the oil pan.
    If that is the case use your old oil pan and press out the the fitting so you can put the old dip stick tube in the 300 block.
    The fitting pin should come out with a few taps.
    Call me if there are any questions.
    See you up at the Northeast Van Show on July 18th.
    Jim in NJ aka Casimier
    732-998-7529
    Old Skool
    Number of posts : 1306
    Post by Old Skool Sun May 24, 2015 10:32 am
    BIGGEST unanswered question I see is WHICH C4????  I dont see any mention of what sized motor the current C4 is bolted up to,,,,  It should be to a 240 motor, ,and if so,, yes, if a small six the answer would be NO as it has a smaller bell housing pattern than the big sixes which it shares with the small block V8's.
      Typically the 300's come with a double pulley crankshaft dampener and use a bolt to hold it to the crank shaft which the 240 normally does not in ours. The fan will hit this bolt and is easily fixed by using a 1/2" fan spacer. In regards to the dipstick,,, the 240 pan and pickup is just fine and knocking out the freeze type plug in the block. Use your old pan and dipstick setup.
      NOTE OLD TRICK:  An easy tip to removing your existing dipstick WITHOUT breaking it is to find a Phillips head screw driver or any round stock for that matter that just  barely goes into the dipstick tube. Push it down to the bottom of the tube and use a pair of vice grips to now grab the tube. This transfers the force to the tube as a solid unit and helps to prevent your bending or breaking it. Slowly turning it as you pull it up and out. Normally works perfectly.
      The 300 has a LOT more torque than the 240 and really gives you some gearing options because it can PULL. I went from a very quick 240 pulling hills easily and looking for another gear at 80,, to loosing steam going up the same hills with 3:25's.
      Put in the 300 and pulls the same hills easily without looking for 2nd gear at the top anymore and had considered dropping the 25's for some 3:00's.
    Old Skool
    Post by wildbillinva Mon May 25, 2015 3:50 am
    cheers yes it is a 240. I knew you guys wouldn't let me down:) thanks for the quick response. can't wait to get the old girl back on the road.
      Current date/time is Sun Nov 17, 2024 1:34 pm
