Hi Group, I can get a rear seat that is 53" wide 22" deep and 38" high. I measured between the rear wheel wells and 53" wide seems short. Does anyone have a picture or know how wide the seat should be? They are hard to find and this guy has a nice vintage one about 30 min from my work.
Rear bench dimensions
hbsurfdave- Number of posts : 41
Registration date : 2015-05-01
dead sailor- Number of posts : 18
Registration date : 2015-03-23
Re: Rear bench dimensions
mine still has the original, but i turned it sideways. the cushion at its widest point is 56".
Best = GO GET IT!!!!!!!!!!!!!!!!
Abitibi- Vintage-Vans Listings Manager
- Number of posts : 479
I think that's an ideal size as it allows you to build a small cabinet over one of the wheel well. I'm in the same process and just found one that reclines but it was too large so i cut if off in the middle, took 12" off and re-welded it to be 52"wide. I made sure i could use the original anchor plates for mine.
Good luck!
Mr. D
Good luck!
Mr. D
Cool, I think I'm going to get it , the extra space on the side will allow my surfboard to hang on the wall.
