One of my dog house lid hinges came off. So I need to reattach it . The lid is covered in fabric, so welding the hinge back on is not the best option. So which would you use gray regular JB weld, or harbor freight clear quick set epoxy. ?
JB weld or quick set epoxy ?
jimthefred- Number of posts : 326
Re: JB weld or quick set epoxy ?
I would screw or bolt it
ditto =above!!!!!!!!!!!!!!!!
You can get snap caps to match things up if you go with screw head type bolts maybe.
Don't know why I did not think of drilling and bolting it back together..some times brain farts and old age don't mix . Thanks for setting me in a better direction
Well using small machine screws and nut worked great. Thanks for having better ideas that I had.
