I have a 302 out of a mustang for my V8 swap and I'm in the process of switching from a rear to a front sump pan due to the cross member location. The problem I'm having is I ordered the melling pickup and the oil pan and when I went to install the pan and the pickup is hitting the bottom of the pan. Does anyone know if the oil pump or the pickup lengths are different or are the pan depths different?
I've already had to switch the timing cover to one with a hole for the dipstick because the original dstick hole is at the back drivers side of the block and is inusable now.
If the new pan I just ordered has the same problem I'm either going to shorten the pickup tube 1 inch or adapt the oil pan accordingly.
