by Sy Hollinshead Sun Mar 29, 2015 1:00 pm
I fitted one on mine, as the travelwagon camper roof was destroyed on the way over to the UK from the USA. It is not an easy job though, the strengthening ribs that run along the length of the roof make life very difficult....!!
You can see in this last photo that i had to weld in a section of flat metal to create a water tight front edge. A lot of welding went into joining the flat section with the original ribbed section. It was very tricky, but the finished result looks lovely, even if nobody can see it from the ground...!!!
Driving it at any sort of speed with the roof open is eventful to say the least, i tend to leave mine closed when on the move.
Not sure i would do it to a van with a good solid roof, you could get aircon fitted for the price of a good ragtop...
