Hey everyone, been a little while. My 1967 Chevy Van, tires are worn inside, it is a "camber" issue. I went to the wheel aligment shop, they say that the van has no adjustment for this;to check the auto stores for camber pins, they didn't have any.
My question is can they be put on?
Where do you buy them?
If not.. how do I correct the tire wear issue?
P.S. Someone mentioned the "axle" slagging possibly, bending a little bit.
Is this true, has anyone had their front axle re-bent to make the adjustment right?
Hope this gives you all the info you need, look forward to the response.
Bill
Bill
