Hi friends. Happy holidays to all!
Ive a 1969 a108 with the 318 engine in ot. Had it running fine till one day it wont drive.Turned out to be the transmission needed a rebuild. Took it to a shop and got that out of the way. Now it won't start. I've been told from the shop that they took it on a short test drive after the tranny rebuild and it was fine. Then all of the sudden it won't start. They said they check the fuel pressure and there was none. So I'm assuming it maybe the fuel pump. The previous owner installed a manual switch (a cut off switch) for the fuel pump (which is electric), as a safety feature I suppose. Anyway, I'm not familiar with these vintage bad boys much. I've worked on motorcycles before. Since the van has a lot more components than a bike, thought I'd ask before I start tearing it down and may be looking into the wrong direction.
Tl;dr: where are some usual location to mount a fuel pump on a108s? From the situation described above, can you think of any other reason to why it won't start?
Thank you,
Thank you,
