well apparently i got some trash in one of the jets on my carb so im gonna have to take them out and i was wondering if it would be worth anything to swap them out for a slightly different size. as far as i know the only thing done is a more free flowing exhaust so i doubt i would see any gains from different jets but i figured it would be a good time to tinker with it if there was a better option than the factory size. its a 1965 170 with the stock carb (as far as i know) any advice is appreciated thanks
stock 170 carb jetting
Mr.Fister- Number of posts : 27
Registration date : 2011-10-07
- Number of posts : 2086
Re: stock 170 carb jetting
If the plugs look good, I'd leave it be. A lot of times the size should be increased a size or 2 to compensate for crappy modern gas which tends to run leaner than the leaded gas of the 60's.
- Number of posts : 2011
thanks for the chart and the diagram barnabas...i took the top off the carb today and checked the main and the needle valve and i couldnt find any trash in there. i put it back together and the same problem was happening...it would idle high like normal and run fine with the choke wide open but when i slowly let off the choke about half way it would start sputtering and die. i could start it back up with the choke on but everytime about half choke it would start to die. i guess im gonna have to dig a little deeper
I assume you meant "run fine with the choke closed". Has the carb ran ok since you've owned the van? Mine did this when I first got it, so I rebuilt it and found 1 check ball missing and the check weight missing on the other check ball. Also could be a vacuum leak, idle circuit plugged, etc. Give it a good cleaning and rebuild with a descent kit and it will probably be fine. Not sure what carb you have, I assume an 1100, if so be aware that the tops on those are the weak point and can have sealing problems b/c they tend to warp. I had that problem with mine but it sealed itself up once the gasket swelled. I think you can soak the bowl gasket in gasoline for a time before assembly and it will help.
