What do you guys do about the side and back door handles sagging?
sagging door handles
wideload- Moderator 1st Class
- Number of posts : 1388
Re: sagging door handles
Take a look at this topic, more than likely this is your problem. You'll have to remove the handle mechanism from the door and tac weld it .
https://vintage-vans.forumotion.com/t28459-droopy-door-handles-dropping-beyond-where-they-re-suppose-to-line-up?highlight=saging+door+handles
Mike
WIDELOAD
+Yes, I've seen several threads on this here and at VCV, all say the solution is the same, you tack weld the hole square again...
