Tech update #4 2nd gen master cylinder.
So now that I have a 2nd gen to do these mods to, I am discovering problems and having a change of opinion on some items.
I installed the low profile aftermarket master cylinder in the 68 G10 today and found four reasons why the 2nd gen master should be consider a good choice.
#1; I had to cut open the mounting bracket wider to fit the new master.
#2; I had to temporarily drop the sway bar and lower the rad a bit to fit the new master into place.
#3: The park brake cable rubs on the side of the master cylinder.
#4: The throttle rod rubs and jams on the top lid of the new master cylinder.
In many cases people are changing their park brake set up and throttle linkage set up all at the same time anyway so to that extent I would still recommend the Corvette style master cylinder.
However: if you are not changing those fore mentioned items and are doing a disc conversion only; you might consider staying with the 2nd gen master cylinder to avoid all that extra work. But if you are staying with the 2nd gen master!!
Oh wait! I now have a 2nd gen master and decided to see for myself. Well look here, just like it states in the data and rebuild kit. It has built in 10lb residual check valves!!!
(not good for disc brakes)
That little top hat thingy with the spring is a 10lb residual check valve. You need residual check valves but you need a 2lb for disc brakes and a 10lb for drum brakes.
You have to pull out the brass furl insert to remove that valve and reinstall the furl if you haven’t destroyed it getting it out. you can see in the previous photo a drove a screw into is and pulled it out of its press fit with vise grips.
Alternatively you could test your master with a gauge but it might be led work just to take it apart , or go to a different master.
I recommend as a minimum; you temporarily install a low pressure gauge (say 0 to 100) onto the master’s outlets one at a time and depress the master only enough to go higher than 40 PSi and not exceed the limit of the gauge or you will destroy it. Then release the pedal and make sure it returns to "0" PSi. and not stay at 10 psi. That will confirm no built in residual drum brake valves and you’re good to go. (Some have the valves, some do not) You will still require other valving as applicable to your conversion.
I still recommend the corvette style master;
#1 If you are doing a first gen you have to cut the bracket anyway and the park brake cable and throttle rod do not interfere.
#2 if you are doing a second gen and changing the throttle linkage to a cable and changing the park brake system to modern "sheathed Cables”.
If you have bought yourself one master cylinder and have not installed it yet, you can always return it saying you ordered the wrong one.
Had to cut open the mounting bracket
The park brake cable drags on the master
