+9
Old Skool
cali2chitown
Devo
FCC
13 posters
    King pin kit on Macs...
    FCC
    FCC
    Number of posts : 295
    King pin kit on Macs... - Page 2 Empty Re: King pin kit on Macs...
    Post by FCC Mon Jun 23, 2014 12:11 pm
    Judging by the size of the grease ball on each side of the axle, I'm gonna say these are probably the original king pins. When I took it to the car wash to blast off all of the mucky muck, it was so old and tough that I could barely cut through to the metal, even with the water blasting it from 1" away.. it took 5$ in quarters to get to where I could see the bearings and the shine on the zerx fittings...
    Number of posts : 12248
    Post by donivan65 Mon Jun 23, 2014 12:14 pm
    but how much does the spindle move up and down,,,,,it will move some,,,,stick a feeler gauge in there and see  how much space is in there,,,,,do both sides,,,,,,see what you got,,,,,
    FCC
    FCC
    Post by FCC Mon Jun 23, 2014 12:22 pm
    I will try and get that info for you tonight. I'm gonna say it moved at least five thousandths.. lets just say, it made me go HM.
    Number of posts : 2198
    Post by EconoUSAparts Mon Jun 23, 2014 12:26 pm
    Not quick enuf on the edit Donivan, yer busted! Chevy came after Ford so it is they who do everything different,lol.
    Post by donivan65 Mon Jun 23, 2014 12:50 pm
    Vic said he don't like to see the word C***y in the E section,,,,,he takes his Ford stuff REAL seriously,,,,,
    Old Skool
    Number of posts : 1306
    Post by Old Skool Mon Jun 23, 2014 2:26 pm
    LMFAO,,,,,,,,,  always the same old, same old,,,,,,,  no big deal,,,,,  Just saying that in this thread that these bushings need to be honed or reamed and that people doing them at least know what they will or should have done,,,,,  People neeeeeeeeeeed to know whats going on in this thread at least,,,
    vic
    Post by donivan65 Mon Jun 23, 2014 2:31 pm
    I am sure people see the good information on the site,,,,,,,sometimes they got to dig through the chatter......some answers come with free entertainment,,,,,,,,,,
    Post by donivan65 Mon Jun 23, 2014 2:57 pm
    So Vic, is that reamer of yours adjustable or 1 size fits all,,,,,what are you shooting for on clearance,,,.001?   how much clearance is too much? Are those kingpin shafts all EXACTLY the same diameter?
    FCC
    FCC
    Post by FCC Mon Jun 23, 2014 4:15 pm
    should be .741 pin diameter... IIRC
    Old Skool
    Post by Old Skool Mon Jun 23, 2014 5:11 pm
    From all that I have done and measured they were identical in OD.  however even that would make no difference as the bushings are under sized anyways. Suppose this was a way of making sure that they were all done to a closer tolerance???  Don't know but honing is MUCH better and yes, I ask for .002 MAXIMUM as in any thing like this they will only wear in and get stuck unless you don't lube them at all. Talking about some major pressure exerted and if fit too loose then even worse.
     The reamers are the adjustable type and come in any size you would want. Years ago lots of major threads and conversations in regards to borrowing someone's and all kinds of people posting ones on EBay for sale.
     Having done all kinds of bushing work its been my experience that the reamer is far less accurate as well as not as smooth a job after wards. The cutters will never leave as good or as accurate finish on them as when done on a honing machine like the Sunnen type. The stones get dressed and the dressing mandrel for the stones constantly getting reversed when used to prevent any taper or differences worked into it. That way it keeps the stones true and the same from one side to the other when used... JUST my experience and so I do all the press work myself and then have a shop with hone machine do them for me.
    Vic
    FCC
    FCC
    Post by FCC Thu Jun 26, 2014 10:27 am
    North side of Cincinnati, Ohio. For those from the area tuning in..
    http://www.brightonspring.com/products-and-services/our-services/sunnen-hone-spindles.html
    FCC
    FCC
    Post by FCC Thu Jun 26, 2014 3:05 pm
    Ok. So, I can't really trust my cheap calipers on the first try.   But I believe the pins from MAC's to be the right .661 measurement. I've measured and re measured and I have decided it true. They are as advertised.
    King pin kit on Macs... - Page 2 C69ABAA1-1887-4451-96CD-4AD726C055AB
    King pin kit on Macs... - Page 2 7422BE00-24B7-4E6B-A0EF-EAED845AD92B
    King pin kit on Macs... - Page 2 81506BC4-D8D4-4FC4-8EBD-5CB4EF43EC63
    Post by EconoUSAparts Thu Jun 26, 2014 7:58 pm
    FCC wrote:North side of Cincinnati, Ohio.  For those from the area tuning in..
    Been using them for years. They used to be closer until they closed the location near downtown.
    FCC
    FCC
    Post by FCC Thu Jun 26, 2014 8:33 pm
    Down by Union Terminal. Right? Under, sorta?
    johnnybentwrench
    johnnybentwrench
    Number of posts : 50
    Registration date : 2013-09-02
    Post by johnnybentwrench Fri Jun 27, 2014 7:41 am
    I just did these and had TED grind the groove so I know for sure its correct. I also found shims under the thrust bearing not good sorted it out and wheels are super tight. John Los Angeles, CA
    Old Skool
    Post by Old Skool Fri Jun 27, 2014 7:48 am
    Good thing,,,,,,,did u get the sway bar bushing numbers,,,,  researched and found them about 10 years ago,, how did the brake lines go on now,,,, LOL.....
    vic
    johnnybentwrench
    johnnybentwrench
    Post by johnnybentwrench Fri Jun 27, 2014 9:40 am
    Good but all week with no knuckle busters until I had to go back in GOOD TIMES
    Post by EconoUSAparts Fri Jun 27, 2014 10:53 am
    FCC wrote:Down by Union Terminal. Right? Under, sorta?
    Yep that's where they were
    johnnybentwrench
    johnnybentwrench
    Post by johnnybentwrench Sat Jun 28, 2014 7:32 am
    well I would not try and do king pins again ever. My wheels are now looser than they were:) I am going to have to non op my truck for awhile. I am going to take the spindle off for the third time today
    Post by donivan65 Sat Jun 28, 2014 10:08 am
    So what is the problem now,,,,,,,does the shaft fit tight in the axle,,,,,,,is the lock pin in there tight,,,,,or is the slop in the bushings???? those bushings probably like to be .0005 larger than the shaft after they are pressed in,,,,,,,,did they get honed or reamed wrong? Or did someone mess with the spindle hole size????
    johnnybentwrench
    johnnybentwrench
    Post by johnnybentwrench Sun Jun 29, 2014 10:35 am
    I did not line the groove up exactly and get to do it again monday after the machine shop swaps the bushings or hones them again. I prefer a fresh start. Going to Vics today for king pin set #2 Sad  good news is I now what was wrong and will fix it just a little bit of a bummer
    FCC
    FCC
    Post by FCC Sun Jun 29, 2014 11:11 am
    Hey. I have a question. Can you get the brakes off the steering knuckle without completely dismantling them? I'm in the planning stages and that was something I was wondering.
    Post by donivan65 Sun Jun 29, 2014 12:19 pm
    you should be able to take the brake hose and 4 bolts out and remove the whole backing plate......
    King pin kit on Macs... - Page 2 Repair29
    johnnybentwrench
    johnnybentwrench
    Post by johnnybentwrench Mon Jun 30, 2014 7:25 am
    looks familiar. Thats how I took it back apart. John
    johnnybentwrench
    johnnybentwrench
    Post by johnnybentwrench Tue Jul 01, 2014 7:23 am
    well finally finished the king pins and they are now tight. John
    Thanks To Ted and Vic for the parts
    update I do not recognize it driving. I really can't believe the difference it feels planted on the ground and goes down the road straight as can be stops too ALL GOOD
      Current date/time is Mon Nov 25, 2024 8:36 am
