Rip !!!! Don't forget This One !!!!!!!!! 1964 ChevyVan Service Bulletin
Vanish- Admin
- Number of posts : 5155
,,,Vanish,,,
MCMLXV
I noticed in this the 64 has a chain on the doghouse lid??? My 64 has the lid rod. Does anyone have a 64 with the chain???
- Number of posts : 12189
Vanish does and I do,,,,,,,,
RipVanArkie- Moderator
- Number of posts : 987
I looked for that one for years! Put it on the tube as soon as I got it!
My 64 has a chain too.
Later,
Rip
Later,
Rip
DanTheVanMan- Commissioner
- Number of posts : 7898
Hmmm, Mine has a rod that you swing up and put on a support hole. Kinda like on a car? Weird.. A chain would be nice....
My 64' has a chain.
dave
dave
So do all you chain gang members have 2 latches on your Doghouse Cover?????? My 65 and Vanishes 64 do along with the chains
Yes sir, two latches.
Later,
Rip
Later,
Rip
Two latches, but only one chain. Am I missing one?
SIX-FO' wrote:Two latches, but only one chain. Am I missing one?
Not unless your is a convertible! lol
Just yankin' yer chain, there is only one chain on the pass. side.
later,
Rip
Literally "Yankin' my chain" haha. I wasn't sure if there was supposed to be another one or not. Now I know. Thanks Rip,
-Ryan
-Ryan
I see the Chevy's use a crossmember for the engine. Interesting. Do the Econos use one? The Dodge's don't.
The Econolines use a crossmember too, 1964 was the only exception...I think. 64 had two arms from the frame that the engine mounted to. How are the A100's mounted?
Later,
Rip
Later,
Rip
Two brackets that bolt to the frame that extend out. The engine mounts to them. Nothing runs under the oil pan.
So is this a rule? If you have 2 latches on your doghouse cover,,,,,you also got a chain to hold it up......can anyone break this rule?
Chevboner- Number of posts : 209
Registration date : 2012-09-15
My 65 only has one latch and a chain...
- Number of posts : 14770
But the chains are only as strong as the weakest link, Right? Would that be the Curly-Q Link? Nyuk, Nyuk, Nyuk!!!
