    Diamond Racing 13x7 wheels
    FCC
    FCC
    Number of posts : 295
    Diamond Racing 13x7 wheels Empty Diamond Racing 13x7 wheels
    Post by FCC Tue May 13, 2014 10:26 am
    I am nosing around for interesting wheels..  I want black tire on a wide 13.
    These wheels are available in 13x7, any offset, any bolt circle with a chrome rim, raw center, and then I could have the centers powder coated off white.
    Is there a fitment issue with 7" wide 13s?
    Diamond Racing 13x7 wheels <a href=Diamond Racing 13x7 wheels Diamon11" />
    Number of posts : 2087
    Diamond Racing 13x7 wheels Empty Re: Diamond Racing 13x7 wheels
    Post by Seth G Tue May 13, 2014 12:13 pm
    Shouldn't be but it always comes down to the tire size moreso than the rim, but with a 13" x 7" there's alot of room there. Can I ask why you want to go with 13" instead of 15"? I mention it b/c 13" rims will keep you from being able to convert the front brakes to disc's if you so choose.
    FCC
    FCC
    Post by FCC Tue May 13, 2014 12:37 pm
    look mostly ..  I was imagining a low, slouchy, fat tire look.  I was asking about rim width, and any potential interference with mechanical parts at that diameter.
    I have 15x7s with 195/50/15s on my 1975 bmw 2002, which also came with 13s, and the look is nice. But that wheel set up is...'perky', as compared to 13s with 205s.  I was hoping to pull off a small rim baloony black wall tire thang, and the van will be lowered later.
    I hear you about the disc brake conversion, that's exactly why I am on 15s with the BMW.
    Diamond Racing 13x7 wheels 64ADD4A4-1BD0-4B25-99C9-BFD343CA3101-624-000000FEDFFAFAF2
    Post by Seth G Tue May 13, 2014 8:58 pm
    So you want more meat on the rim? If you ran 17's it would look more like the beamer there, I've considered that. 7" isn't a problem, you can even go 8" w/ stock setup all around depending on section width and rim offset. Actually you can get away with 8" in the front and 9" in the back if careful about it. I have some measurements I've taken off the hubs on real width limits on my van. I'll try and find them.
    FCC
    FCC
    Post by FCC Wed May 14, 2014 6:52 am
    After a fairly deep tire search, there isn't much available beyond 185/13s unless you want a track tire, or want to pay Coker prices for a vintage tread. Like, a grand for four tires. L no.
    Also, while they do not list the "D window" wheel center in a 15" rim option, they have them in stock at Diamond. So the vision I was having for the chrome/creme look could be achieved in a 15X7 config. But the more I look at the stock wheel look, the more I like it. Too bad Stockton wheel shut down. wonder if diamond wheel would re-weld my centers into an offset that would push the stock rim out some... ?
    I need to stay focused on getting the steering and suspension refurbished before even seriously looking at wheels.
    Number of posts : 2198
    Post by EconoUSAparts Wed May 14, 2014 4:58 pm
    13 tires are hard to find,14's are even getting tough to locate. I would go 15 if possible. I can show you 16's here on a van. A buddy here in Cincy cut and widened his 15" Galaxy rims for a deep dish look that fits the stock hubcap for his 61 Econo.
    FCC
    FCC
    Post by FCC Wed May 14, 2014 5:37 pm
    Dood. Saturday morning.. round 'em up.
    Post by EconoUSAparts Thu May 15, 2014 3:14 am
    FCC wrote:Dood.  Saturday morning..  round 'em up.
    Working which is pretty much the norm for me on Saturdays anymore. Can't pass up the O.T.
    FCC
    FCC
    Post by FCC Thu May 15, 2014 3:52 am
    I knew that. Sorry. Forgot.
    Soon though.
    Old Skool
    Number of posts : 1306
    Post by Old Skool Fri May 16, 2014 11:52 pm
    Its the age old thread about that its the OD of the tire as far as lowering a truck goes. You can get much better tread and tire selections in 15" than any other and fit larger brakes in at the same time. Point I am making is perhaps you can get close or closer in the OD that you want, but in 15" tires. Wont bore everyone again about the 16.5 story,,, LOL..
      Anyways,, I didn't also hear you mention front or rear??? On my rears I will be running 8" Cragers in the rear but will have to ROLL the lips so they will clear, on the fronts the widest I would use would and will be my 6" Cragers,,,,,
     The issue with ours is the lower front corner on the fronts. On one of mine I moved the axle rear ward 1" so that I could run bigger tires and get some room there without chopping up the wheel well to do it.
    Vic
    Post by EconoUSAparts Sat May 17, 2014 4:33 am
    Vic, how'd ya move the axle back?
    Old Skool
    Post by Old Skool Sat May 17, 2014 6:30 am
    Tim,,,,,   I used a masonry carbide drill bit and drilled a new hole for the spring pack bolt. The bolt being nothing more than a grade 8 with the head ground down to use as an alignment dowel. The spring material almost impossible to drill.
      Previously, I had already moved the ball joint by cutting a new taper on the top of the steering arm and had made an adjustable drag link. (left/right)
    VDiamond Racing 13x7 wheels 100_0514ic
    FCC
    FCC
    Post by FCC Tue May 20, 2014 8:33 am
    I'm sticking with the skinneys.  Until the day they stop selling all-weather 185/13s.  We've fallen in love with the look. Besides, I can't even imagine how bad it would follow ruts with bigger meats. The new shocks helped, but man, front end/steering on this this needs serious refreshing.
    Diamond Racing 13x7 wheels 7AE42E67-6F54-4775-B7B0-2C6EA5E9AF3B
      Current date/time is Tue Jan 14, 2025 4:09 am
