gkpost
    Door felts
    gkpost
    gkpost
    Number of posts : 224
    Door felts Empty Door felts
    Post by gkpost Fri May 09, 2014 4:45 am
    Looking for door felt kits. I need everything for both doors .I can't seem to find wookie.
    Any info on where and how would be helpful .
    Thanks ~ GK.
    Door felts Empty Re: Door felts
    Post by Joe Van Fri May 09, 2014 5:21 am
    Number of posts : 2632
    Post by savage Fri May 09, 2014 5:27 am
    Have you tried over on VCVC?? Don't think hes on here much??
    Also Clesters Auto Rerpoductions got them in ther catalog ( www.clestersauto.com ) or 1-800-457-8223
    part # CT-322  I have not used them,so don't know how they fit
    Number of posts : 1412
    Post by Vantasia Fri May 09, 2014 7:11 am
    I used this set, but shop around, I found it also on eBay for $75 plus shipping, under $90.  The kit is good but the felt strips need to be trimmed to length, they were about 1-inch too long for a first gen and the clips are flimsy, had to modify and even epoxy a few spots with JB Weld to make them fit snug to the door edge, but they are the only kits around.  If you are doing this for the first time, follow the shop manual for removing the glass properly, I almost broke one of mine trying to squeeze it out the wrong way.  Getting the guide strip into the track all the way around is a "bear" too but take your time and it will come out great, mine did.  One more thing, the kit does not come with the vertical vent window frame fuzzies, only the bottom belt lines, I used my old ones, they weren't too bad.  If they are gone, you have to do major surgery to remove them and replace them using a special rivet tool made for this purpose or fabricate substitute tracks, search the forums for threads on that.
    Number of posts : 801
    Post by panelmanrd Fri May 09, 2014 12:00 pm
    might try restoration specialties inc
    mikeysly
    mikeysly
    Number of posts : 284
    Post by mikeysly Sat May 10, 2014 2:17 am
    Anyone know where you can get the chrome beaded channel?
    Post by savage Sat May 10, 2014 4:39 am
    J C Wihitney
    mikeysly
    mikeysly
    Post by mikeysly Sat May 10, 2014 8:55 am
    Savage do you know which model/dimensions? (sorry)
      Current date/time is Thu Nov 21, 2024 9:43 pm
