Ok since I am actually working on the 63 falcon again I am going to tear the doghouse off to do the alternator conversion. Since I am removing it and it looks to be a little bit of a pain I figure I will redo it while its off but have a couple questions.
1. There is some kind of a rubber/foam (glued??) around the outside of it. Is this something that was done? Easiest to way to remove it?
2 Do you guys only wrap the inside sides for Heat and noise or just the lid?
3. Any other thing I should consider?
