It's Been a while.....
Finished welding up in the front, blasted it, primed it.
I rotated the rack.... as if it was executing an in place summersault, in the direction of the nose.
Before:
Spent a lot of time to ensure the rack would remain in the same X/Y/Z location, simply rotated a bit.
Had to figure out how to make a functional bracket.
(Ignore the coat hanger, I wanted to make sure nothing would hit the ground,
) This shit just might work.
Sitting in the driver position, when rotating the 'steering column' shaft clock wise the wheels turn right. Counter clockwise, they go left.
Now I have to finish welding up the brackets and obtain the correct bolts. Fab up a bracket to hold the steering box and go from there.
Fuel. I bought and test fit several and then returned all but one. Stopped just short of having a custom one made for my application....wish I had a tig welder... (still an option, I'm still on the fence).
The nearly perfect fit one is only 17 gallons.
http://www.summitracing.com/oh/parts/rci-2172a/overview/ I would prefer a larger capacity tank, but there are many factors.
Regardless, it was a great opportunity to do a rough mock up of the air management stuff.
turns out a 5 gallon Cornelius keg is about the same size as a 5 gallon AccuAir tank, lol. ;-)
hopefully, more to come soon.
